工业铝材是我们常见的一种型材,而且用途是十分广泛的,工业铝材是其用途之一,其是一种以铝为主要成分的合金材料,一般是指除建筑门窗、幕墙、室内外装饰及建筑结构用铝材以外的所有铝型材。那么遇到工业铝材硬度过低该怎么办呢?让小编来为您介绍一下。
工业铝材硬度过低,可以进行温的设定与控制,一般情况下,温与表显温度存在一定的误差,设定表温时要根据炉子的实际温度来设定,并且要密切关注温的波动情况;还可以进行时效保温,要严格按照工艺要求来进行时效,保温时间要适当,避免欠时效或过时效,导致硬度不够。
另外,工业铝材挤压装框不能过密,料与料之间要有间隔,尤其是不通风的小料、厚料间隔更加要大,管料与小料、板料合装一框时,管料放下面有利于时效循环送风。
Aluminum is one of our common profiles, and use is very extensive, industrial aluminum is one of its purpose, which is a main component of aluminum alloy material, generally refers to the addition to building windows and doors, curtain wall, indoor and outdoor All decorative and structural aluminum with aluminum outside. Industrial aluminum hardness is too low then the encounter how to do it? Let Xiaobian to introduce you.
Industrial aluminum hardness is too low, you can set and control the temperature, under normal circumstances, the temperature and the temperature of the table there are some significant errors, setting the table when you want to set the temperature and the actual temperature of the furnace, and pay close attention to the temperature the fluctuations; insulation can also be aging, should be strictly in accordance with the requirements of the aging process, the holding time should be appropriate to avoid under-or over-aged aging, resulting in insufficient hardness.
In addition, industrial aluminum extrusion framing is not too dense, there must be separation between the material and the material, especially in the small unventilated material, thick interval of more material to be big, small tubing material, sheet metal together packed in a box , put the following in favor of pipe material aging air circulation.
上一篇: 铝合金门窗历史发展 下一篇: 铝合金门窗设备的配置
